After I updated to the latest app on my iPad the icon has gone blank, just showing the kind of default icon for iOS Apps (white:ish with lines), apart from that the App works fine.
I have tried delete the App and install it again, but with same issue.
I will look into it, thank you for your feedback.
I didn’t use app on iPad until just now.
Yes, iPad is missing on icon. Also, doesn’t look like app was designed for iPad as I can see scaling button - 1x 2x.
Yes, Yeelight app is designed for iPhone as so far, and just run in compatibility mode on iPad.
Hi, Niklas
Solved the problem?
Try to update your iOS system to the latest version.
If it is not working, either. Try TunesKit iOS System Recovery.
BR
Sebastian
