Problem: only red color possible with yeelight extended lightstrip
Dear reader, i only have the red color available whatever scene i select on the new yeelight strip, extended with a few meters. The strip has the latest firmware, however i am not able to change the color… can someone help me please? Thank you
It would be helpful if you provider a video to show the issue.
https://youtu.be/GSBHv5hoeKA
It seems a hardware issue, please contact your retailer for a replacement.
@Armando
Please double check the connector between the main strip and the extended strip.
I have the same issue. The main strip and 2 extensions were working fine when I tested it out of the box. I installed it, put the power on and only red colour is possible. Also a hard reset doesn’t work, it should blink red, green and blue but it’s only red.
How can this be a hardware issue if it worked fine 5 minutes before I installed it?
I still have the problem. The seller is not responding anymore, wont Give me a new product or refund… worthless seller
That sucks. I just sent a message to my seller, I hope he’s more willing to help.
@dingyichen
Can someone from the Yeelight team shed more light into this issue? As we already have 2 people on this thread with the same issue I assume this issue is known at your end? Is it confirmed to be a hardware issue?
My seller is also not willing to send a new one so I spent almost 40 euros on something that is broken within 5 minutes after opening the box. Definitely not the quality I expect of a product in this price range for led strips.
I would also like you as yeelight staff to step in on this case, since it is a ‘common’ issue with the product and clearly Some Sellers wont keep their promise on refunds or replacements.
After spending some time on it again I solved the issue!
For me the problem was at the part where the led strip and the power cable comes together. I didn’t know the led strip could be removed from the power cable. During the installation these 2 parts got loose and were not completely connected.
It’s this part I mean:
When I touched it there the colour immediately changed :slight_smile:
Thanks for your information, good to know it works.
Hello i have the same problem with you how did u fix yours? did you only press?
Thanks for your information!!! I did the same procedure and now it’s working!
