I cant connect to my yeelight bulb e27 color because of “connection timeout” problem.
Hello Dingyichen,
i am having the same issue i have gone through all the steps. the lamp is not in my dhcp.
i still can’t connect to it as it always fails at 99%. i have attempted multiple times.
how would i “connect the bulb” to the 4g network?
very frustrated as i have spent a lot of time resetting and pairing to the app.
thanks.
i had this issue and for me what solved it was to go into Iphone general settings search Mi Home app and confirm Local Network access was granted, this worked good
