Hi !
According to the specifications, a new property called “active_mode” was added recently. I try to get the values of all the properties defined in Table 4-2 of the spec by a single call, but when I add this property I get the following error : “{“id”:(null), “error”:{“code”:-1, “message”:“invalid command”}}”.
I’ve done many tests, and it seems the error is not caused by the property itself, but when the message’s size reaches 256 characters.
Can you confirm this ?
Also, is it the same for the other methods (like “start_cf” etc.) ?
Regards,
Romain.
