Hey guys,
i am currently using the first generation Yeelight LED Bulb, which works just fine for my purposes - so far. I recently got my hands on an Alexa Dot, which I wanted to use for light control.
Even though the bulb seems connected with the skill, is pickable in the routines and responds to my app, it doesn’t work with Alexa.
I am basically getting the answer “Yeelight LED Bulb is not answering”, but it is in the same network and accessable by app. Any advice on this problem?
Greetings & thanks!
Solution: It’s awfully helpful, if you select the correct region. Due to a fix i was temporarily on the Chinaserver, even though I am living in Europe.
