Hi, can you add me to whitelist?
My MI account is 1555181982.
I’m using Chinese server
Hi! Why I didn’t see 1.5.9_0184 in my app? I see only 1.5.9._0043 for 480 lamps and 1.5.9_0053 for 650 lamps. I’m on Chinese server.
Hello, I have a problem (Yeelight LED ceiling lamp 650 mm), after upgrade firmware to 1.5.9_0053 the backlight stopped working. It does not work at all but application shows that it is turned on. Mi 1711916382, Chinese server. Please, help.
Hello, please add me to the list, so I can try to fix my problem which is described in my created topic.
My ID: 1682418677
Just updated my 650 ceiling light to 1.5.9_0053 and no problems so far. Was hasitating after reading about all issues but that red dot was making me crazy. No issues with ambilight and seems to respond quicker now. It’s interesting why only some people have those issues.
hi, can you add me to whitelist.
My ambient light does not work anymore. Perhaps a firmware update helps.
My Mii Acount 1718647356 Server: Deutsch
Hi I bought ceiling light. It worked very bet… it was offline everytime when I turn it off and on on the wall switch. I must reset the light, and add it again in the app. I updatet firmware 5.9, but I can’t connect to the light. It shows me that message can’t be sent. I change the light in the store and i bring the new one, but it was a same. What can I do. How can I fix it? Is there some hide usb plug or something like this, on the device? How can I repair It when I can’t connect to device?.
Why are you turning it off from the wall switch??
Because… it is most common way how to switch the light.
Same here!
