Posting this publicly so other owners can confirm, and so the Yeelight Matter firmware team can reproduce it. I have also emailed support@yeelight.com with the same details.
Device
- Yeelight Smart LED Strip Lights, part number YLYDD-0095, Matter over Thread
- Matter Vendor ID 0x1312, Product ID 0x0004
- SoftwareVersion 7 (“4.0”), HardwareVersion “v1.0”
- Two units, both affected
- Controller: Apple Home with HomePod mini as Thread border router. Also reproduced with matter.js 0.18.0 as the only controller.
Symptom
With Apple Home Adaptive Lighting enabled, the strip turns itself ON some minutes after being turned off. Apple Home keeps showing the light as off until the strip next reports its state. No automations or scenes. It is not a reboot: GeneralDiagnostics UpTime keeps increasing and RebootCount does not change.
Reproduction (Matter level, no Apple involved)
OnOff.Offon endpoint 1. OnOff reads false.ColorControl.MoveToColorTemperatureon endpoint 1 withColorTemperatureMireds=400, TransitionTime=0, OptionsMask={ExecuteIfOff=1}, OptionsOverride={ExecuteIfOff=1}. Response: Success.- Read OnOff. Actual: true (the strip lights up). Expected: false. ColorTemperatureMireds should update to 400 while the light stays off.
Control test
The same command while off with OptionsMask={} and OptionsOverride={} is correctly ignored: OnOff stays false and the colour temperature does not change. The ColorControl Options attribute is {ExecuteIfOff: false}.
Why it matters
Matter Color Control spec (Options / ExecuteIfOff): a colour command executed while off must only update colour attributes and must not change the OnOff state. Apple Home Adaptive Lighting sends exactly this command to pre-set the colour temperature of lights that are off, so every YLYDD-0095 in an Apple Home with Adaptive Lighting on is affected.
Other observations
- The Matter DCL lists no OTA update for VID 0x1312 / PID 0x0004, so Apple Home cannot offer a fix.
- A factory reset did not remove the Matter fabrics: after the reset the strip still held its Apple fabrics and Thread credentials.
Workaround for other owners: in Apple Home, open the strip’s settings and turn Adaptive Lighting off.
Request to Yeelight: please confirm, and publish a fixed firmware to the DCL as a Matter OTA update so Apple Home can install it.
If you own this strip and see the same behaviour, please reply with your firmware version and controller.
