My Yeelight light cannot turn off the gradual dimming when turning on.
I am writing to request a firmware downgrade for my lights due to a specific bug introduced in the latest update.
The issue occurs when using the physical Flex Switch (凌动开关). Even though the “gradual brightening” feature is turned off in the app, turning the lights on via the physical Flex Switch still causes them to brighten up slowly.
Interestingly, turning them on/off via the software app works perfectly fine, and turning them off via the physical switch is also completely normal. The issue strictly happens when turning them on using the physical Flex Switch.
All Yeelight devices currently bound to my Mi Home account are experiencing this exact same problem.
Here are my account and firmware details:
  • Mi Home ID: 2530764786
  • Current Firmware: 1.1.3.0002
  • Target Firmware: 1.1.1.3.0001 (or the stable version prior to this update)
  • Affected Devices: All Yeelight lights under this account (currently 2 lights)
Please push the downgrade firmware to my Mi Home ID so I can restore my lights to normal operation.
Thank you for your help.
