BellSouth email not receiving emails, +1–830–272–7656 such as spam folder, browser cache, email filters, and email forwarding. If none of these work, contact BellSouth support at +1–830–272–7656 for assistance.
If BellSouth email isn’t working for you, there are a few potential issues that could be the cause.
In some cases, both ad blockers and outdated internet browsers can stop BellSouth email from working.
You should also make sure that you’re sending emails to the correct addresses, and haven’t accidentally blocked anyone.
Why am I not receiving emails on my BellSouth account?
If your BellSouth email is not receiving emails, there must be a critical aspect missing. This is why you aren’t receiving any emails at all. It is quite an issue. Emails sent to your account can stop due to numerous reasons. Here we are naming a few:
- Server issue: Chances are the AT&T BellSouth servers are down or under maintenance which is why you are not receiving emails in your BellSouth email.
- Account setting errors: You might have accidentally tweaked the account settings wrongly which is why you are not receiving any emails.
- Verify the block list: Accidentally, you might have added the sender’s email ID to the block list, so you are not receiving the email from them in your inbox.
- Your browser cache is conflicting: Corrupt browser cache can often cause the browser to misbehave and malfunction.
- The AT&T Mail app isn’t updated: An underlying bug might be causing the problem with the app. If so, the temporary error 15 may also show up on your screen but we’ve already discussed how to address it.
Let us now look at the troubleshooting solutions that will help you fix the BellSouth email not receiving emails problem.
How do I fix BellSouth email not receiving and sending emails?
Before applying any advanced solutions, we would suggest you resolve the problem using the below-mentioned quick fixes.
Check if the AT&T servers are down or not. If yes, then all you can do is wait for the servers to go up and if this fixes the issue.
Change the browser and check if using a different browser resolves the issue.
Try restarting the AT&T Mail app and then signing in with your account to resolve the problem.
Sign out and re-sign into your BellSouth account and check whether this fixes the issue.
If you’re using the AT&T Mail app, try reinstalling it.
Let us now apply the advanced troubleshooting solutions and check if this resolves the issue or not.
Verify the Block List
Open BellSouth.net on a web browser and sign in to your account.
Click the Settings icon and select More Settings.
Click on Security and Privacy.
Check if the sender’s email is listed there. If so, then select it and hit the Delete button.
This procedure will remove the sender’s email from the blocked list. Now you can ask the sender to send the email and see if this resolves the issue or not. However, that solves the problem only if you’re not receiving emails from one or more senders that you blocked.
Clear the Browser Cache
Launch your browser.
Click on the menu icon and select Settings.
Select Privacy and Security from the left.
Click on Clear browsing data.
Check the boxes for Cookies and other site data and Cached images and files options along with Browser history.
Hit the Clear data button.
Revisit the AT&T Mail website and sign in to your account.
Check Your BellSouth Account Storage
Open the AT&T BellSouth website on a browser and sign in to your account.
Click the Settings icon and click on More Settings.
Check the storage space left in your BellSouth account on the bottom-left of the page.
AT&T BellSouth email gives 1TB per user for an BellSouth account, i.e., 1000GB. If there is no space left in your BellSouth email, then you need to make room for the incoming emails. For that, you need to clean up the trash or spam folders. Also, you can take a backup of all the old or large emails and delete the emails that have large attachments that you no longer require.
Check the Email Filters
Visit the BellSouth website on a browser and sign in to your account.
Click on Filters on the left panel to see all the filters you have created.
You can locate and delete the filter that is blocking the email that is being sent to you.
BellSouth email lets you use up to 500 filters to sort your emails. This is a nice feature to quickly jump over to the emails that matter to you. However, having filters can also accidentally send emails to spam or some other folder.
Contact BellSouth Support
If none of the above step’s work, it may be time to contact BellSouth support. You can reach out to them via email or call the BellSouth customer support line at +1–830–272–7656 to get assistance with your issue. They will be able to provide you with more personalized support to solve the issue.
In conclusion,
If BellSouth email is not receiving emails, it can be frustrating, but it’s not a problem that cannot be solved. By following the steps mentioned above, you can easily fix this issue and continue using BellSouth email without any further problems.
