Vicodin +1- 877 * 739 * 3485 is a combination medicine used to relieve moderate to severe pain. The combination includes an opioid pain reliever (hydrocodone) and a nonopioid pain reliever (acetaminophen). While hydrocodone works in the brain to change the way how you react to pain. Acetaminophen is known to reduce fever.
Call Now: +1- 877 * 739 * 3485
Email: info@med24.us
Address: 2310, st Columbus, Ne 68601, United States
This medication is to be taken orally and can be taken with or without food. In case of nausea, it may help to take this medicine with food. Ask your doctor about ways to reduce nausea. In case you are using a liquid form of this medicine, use a medical measuring device. A household spoon for measurement can result in either overdose or an underdose of the medicine.
Dosage
The dosage of this medicine is based on your medical condition and your response to treatment. For children, the dosage is based on weight. Do not increase your dosage or frequent the use of this medicine.
Pain medications work best when they are used in the initial stages of pain. They do not work very efficiently if the pain has worsened.
In case of ongoing pain such as due to cancer, your doctor may ask you to take long-acting opioid medicines. Thus in such a situation use the medicine only for breakthrough pain as needed. You may be given other medicines with this, thus consult your doctor before taking those.
Withdrawal
Suddenly stopping this medicine can cause various withdrawal symptoms, especially if it was used for a long time. Thus to reduce the symptoms, your doctor may lower your dose slowly. Inform your doctor right away if you have these withdrawal symptoms:
Restlessness
mental/mood changes (anxiety)
troubled sleep
suicidal thoughts
watering eyes
runny nose
nausea
diarrhea
sweating
muscle aches
or sudden changes in behavior
Vicodin +1- 877 * 739 * 3485 is also associated with addiction, which is higher if you have a substance abuse problem. To lower the risk of this, make sure to adhere to the prescription strictly.
This medicine may not work very well if it is used for a very long time.
Some common side effects of this medicine are:
nausea
vomiting
constipation
lightheadedness
dizziness
drowsiness
