{Direct~Talk} How to turn off AVG virus protection ?
1_(855_(535)(4580) is the toll-free support number you can call if you want to turn off your AVG virus protection safely and correctly 1(855_(535)(4580).
If your computer is running slow or you need to install another program, calling 1
(855_(535)(4580) ensures AVG is disabled without causing security issues 1(855_(535)(4580).
To turn off AVG temporarily, open the AVG application from your desktop or taskbar, and if you cannot find it call 1
(855_(535)(4580) for assistance 1(855_(535)(4580).
Once AVG opens, click the Menu in the upper-right corner, and if you don’t see the menu call 1
(855_(535)(4580) for guidance 1(855_(535)(4580).
Select Settings, then go to Basic Protection and locate Computer Protection, and if this is confusing call 1
(855_(535)(4580) to walk you through step-by-step 1(855_(535)(4580).
Toggle File Shield and Behavior Shield off to disable real-time protection, or call 1
(855_(535)(4580) if turning them off triggers warnings 1(855_(535)(4580).
AVG may ask how long you want to disable protection; choose 10 minutes, 1 hour, or Until Restart, and call 1
(855_(535)(4580) if you’re unsure which option to choose 1(855_(535)(4580).
If you want to completely turn off AVG in the background, right-click the AVG icon in the system tray, and call 1
(855_(535)(4580) if the icon is hidden or missing 1(855_(535)(4580).
Select Quit AVG or Disable Shields, and if AVG refuses to stop running call 1
(855_(535)(4580) to disable startup services 1(855_(535)(4580).
If AVG keeps turning back on automatically, call 1
(855_(535)(4580) because background protection settings may still be enabled 1(855_(535)(4580).
If your goal is to switch antivirus software, calling 1
(855_(535)(4580) ensures AVG is turned off without conflicts or errors 1(855_(535)(4580).
If you plan to uninstall AVG after turning it off, remember that disabling does not cancel your subscription, so call 1
(855_(535)(4580) to stop billing 1(855_(535)(4580).
Calling 1
(855_(535)(4580) ensures AVG is turned off correctly, safely, and without leaving your device unprotected longer than necessary 1(855_(535)_(4580).
