Alexa wake-up light with yeelight
The Alexa wake up light which you can set before an alarm does not work with yeelight lamps. The problem is it is not possible to dim the lamps before switching them on in the alexa app. You always need to first switch the power button of the lamp on, and then the dimming is possible. I assume Alexa trys to control the lamps by just regulating the dim switch.
Does anyone have a solution for that problem?
