Bedside Lamp D2 turns on by itself!
Device turns on by itself, in the middle of the night and in the middle of the day. No integrations, no schedules during that period, factory reseted once but nothing changed!
I don’t think the power was down every day at that time!
For nearly a year, the same bedside lamp has been exhibiting the same unexplained automated behavior: it turns on at sunrise and shuts off 1-2 hours later, suggesting a rogue circadian-based automation. Despite thorough checks across all smart home apps, I’ve found no configurations causing this, nor a way to audit the triggers. To resolve this, could I access device logs to identify the root cause and/or perform a factory reset with a new device identifier? This would rule out potential external control via legacy credentials. Any guidance is appreciated!
I somehow managed to stop it’s own startups by changing the charger. I have some schedules but it sometimes keep in mind of it, sometimes not. If i execute a command from phone i have a big delay until the lamp takes action.
In my case, it only stops when I remove the lamp from the Yeelight app and leave it disconnected. If I connect it again, the self on/off cycle resumes.
Try creating another account in yeelight app.
