Yeelight LED Bulb Color Not Resetting and Connecting to Wi-Fi
I’ve been using the Yeelight LED Light Bulb Color for a few years, and it worked perfectly before. Recently, I moved to Canada and bought a new lamp to use the bulb. However, I’m unable to reset it and connect it to Wi-Fi.
I know the reset process, and the bulb starts blinking red, green, blue, but then it goes to a yellow light (the color I had previously set). It doesn’t go to the default white light after resetting, which I believe is necessary for the setup process.
I’ve tried multiple times but still facing the same issue. Could someone please guide me on what to do?
Thanks in advance!
