Hi everyone,
I’m facing some issues with automating a Yeelight.light.color4 bulb and a Shelly1Plus switch using Google Home on Home Assistant 13.2.
Setup:
- Yeelight bulb: Directly connected to the power supply, always online.
- Shelly1Plus: Wired to control the physical switch.
- Home Assistant: Version 13.2
- Automation: I’ve created two automations and two scripts (attached) to sync the state between the bulb and the switch.
Problem: When I control the Yeelight bulb using Google Home or the Yeelight app, the automations don’t trigger, and the Shelly1Plus state remains unchanged. However, if I control the Shelly1Plus directly through Google Home or the Shelly app, everything works fine.
I’ve also tried creating automations directly in Google Home, but I’m still facing the same issue.
- Any logs is present on Hassio when turn on the light by GoogleHome or YeelightAPP
Here are my automations and scripts:
alias: Sync Light with Shelly
description: Sincronizza lo stato della lampadina con lo stato dello Shelly
triggers:
Automazione 1
- entity_id:
- switch.shellyplus1_toggle_boa
trigger: state
conditions: []
actions:
- action: script.sync_light_with_shelly
data: {}
2 automazione
alias: Sync Shelly with Light
description: Sincronizza lo stato dello Shelly con lo stato della lampadina
triggers:
- entity_id:
- light.yeelight_boa
trigger: state
attribute: brightness
conditions: []
actions:
- action: script.sync_shelly_with_light
data: {}
1 script
sequence:
- choose:
- conditions:
- condition: state
entity_id: switch.shellyplus1_toggle_boa
state: "on"
sequence:
- target:
entity_id: light.yeelight_boa
action: light.turn_on
data: {}
- conditions:
- condition: state
state: "off"
sequence:
- target:
action: light.turn_off
data: {}
2script
sequence:
- choose:
- conditions:
- condition: state
state: "on"
sequence:
- target:
action: switch.turn_on
data: {}
- conditions:
- condition: state
state: "off"
sequence:
- target:
action: switch.turn_off
data: {}
I’ve followed this guide for the initial setup: [Link to the guide] But I’ve created my own automations instead of using the ones from the guide.
Any help or suggestions would be greatly appreciated!
