i got received my new Xiaomi Mi Ceiling Light 350mm. I was able to add it to Xiaomi Home but found that you cant select a simple default mode when using the classic light switch. It cycles between 3 modes and you can make two the same but cant delete the moon mode.
Wanted to add to yeelight app to check if there you can choose just one default mode like I have on my yeelight bulbs, but impossible to sync. Tried 3 phones and an iPad, none shows the ceiling light to add.
Any idea how to add it to yeelight? Any other way to eliminate the cycle on power on and make just a simple one standard mode?
Thnx!
