Does GU10 Color w1 bulb remember it’s color and dimming settings after switched of via power switch? So in case it’s powered off through a regular hard switch, it will be unpowered, next time the switch is turned on, it bulb will use it’s last color and dimming power that was set? I saw somewhere that “defaults” can be set via mobile app, but does it work also when bulb is unpowered through a hard switch, or only when it’s turned off by mobile app? Thanks a lot!
通过电源开关关闭后,GU10 Color w1 灯泡是否会记住其颜色和调光设置? 因此,如果通过常规硬开关关闭电源,它将断电,下次打开开关时,灯泡将使用上次设置的颜色和调光功率? 我在某处看到可以通过移动应用程序设置“默认值”,但是当灯泡通过硬开关断电时,或者仅当灯泡被移动应用程序关闭时,它也可以工作吗? 多谢!
