Can’t change the color temperature on yeelight MJXDD01YL after last firmware update. Now it’s 2.0.6_027
If i try to change colour temperature from 5700k to 3000k only brightness is changing. If I set 2700k the lamp is going almost dark.
In “night” mode colour temp is ok, but brightness is too low.
How can i fix it, or how can i roll-back the previous firmware??
I have the same problem, it is very annoying because now I can’t get a more natural color light. I am stock with the very white color. Just like you when I try to change color temperature it just change the intensity of the light.
I guess we are not only two with the same problem.
Anyone as a solution?
I’ve got this problem too. It’s been almost 2 weeks now.
Changing temperature to 6500k just turn the light blue.
