Best Solution to Convert Apple Music to FLAC Losslessly
Just like iPhone and iPods, Apple Music is highly popular among music lovers. No doubt Apple Music gained a whopping 72 million subscribers worldwide as of June 2021. We all know Apple Music is the second-largest music streaming service worldwide and has about 75 million songs, and is continuously upgrading. With the Apple Music app constantly evolving, you can easily find any exclusive song as soon as it gets released.
But then why do users often go looking for an Apple Music Converter? It is because the songs on Apple Music are DRM protected, which restricts them to playing within the Apple Music app only. So, how can a music lover get their favorite songs on another device, without the Apple Music app, maybe? Well, this is what this article is all about. We will guide you on how to convert Apple Music to FLAC, a highly famous file format supported by all devices.
Part 2. Best Apple Music FLAC Converter: How to Enable and Convert
Apple Music is DRM protected, which prevents you from sharing the music with others. By locking the songs and audio to one device, the only DRM aims to protect the copyrights of the content. Thus, making it difficult to convert Apple Music to FLAC smoothly. So, before you can enjoy high-quality Apple Music on any device of your choice, you need to remove the DRM protection and then download Apple Music songs to FLAC without a glitch.
Removing the DRM on Apple Music and converting your favorite songs into FLAC becomes super easy when you have the perfect tool that requires simple steps, ensuring a smooth conversion. Tunelf Audio Convertor is a high-quality converter that supports both Apple Music and iTunes audio conversions. It allows users to convert Apple Music, iTunes, and audio into any file format of their choice at a faster speed with just one simple click. Download Apple Music to FLAC using Tunelf Audio Converter and enjoy limitless Apple Music on innumerable other devices.
Part 3. How to Convert Apple Music to FLAC
To download Apple Music to FLAC, use Tunelf Audio Converter. It will also remove the DRM protecting the music files and will give you a high-resolution lossless file that can be transferred to any Android or iOS device with ease.
Step 1 Add Apple Music songs to convert
Download Tunelf Audio Converter on your Mac device. Open the app on your device, and you will see three options at the top of the page. Choose the first icon and start loading your Apple Music to the converter.
audio converter interface
Step 2 Set FLAC as the output format
A format panel will open up in the next menu. Choose FLAC as your output format. Besides, you can also adjust other parameters from the options given in the format panel. Set the bit rate, codec, sample, and channel from the given options. After adjusting all the options press “OK“.
select output format
Step 3 Convert Apple Music to FLAC
Then you need to go to the first page of the Tunelf to start the conversion process and to remove DRM from the selected songs and audios. After setting up all the requirements press “Convert” to start converting Apple Music to FLAC which can then be transferred to other devices as well.
convert Apple Music
>>> Check the full page.
Nice post :clap:
I used to convert Apple Music to FLAC via DRmare Audio File Converter. It is quite similar to the tool you introduced here. And the one I use has a nice and clean screen. :laughing:
