Simple thing. When I wake up at the midnight to go to the toilet I don’t want the light to switch on to it’s full power. Is it possible to make the bulb use 1% brightness when switching it on between 23:00 and 05:00? I thought that scheduled scene on brightness adjustment in Mi Home app would do the trick, but unfortunately it has no effect when the bulb is turned off. Even though the logs state that scene completes successfully the bulb turns on using brightness it had when it was turned off last time.
