Hello, I have a Yeelight LED Ceiling Light 480 bought 2 years ago. A week ago, it began to disconnect from lan and bluetooth. It helps only to turn off the power switch and everything works again. Firmware 2.0.2_0048 . Could you take a look. ID 139994083 Reset to factory settings did,
Should I add it to the whitelist!?
I have added your account to the whitelist, please upgrade to the latest version
Please add my “Yeelight LED Ceiling Light” to the whitelist too, so that I can update the firmware, otherwise they also lose control for me.
ID 4150007931
Done, please have a try.
Yes, I have already updated the firmware, thank you
Hello, same problem. Can you help me? Id 1670076882
Hello, could you please add me to the whitelist. My 3 Smart bulbs W3 and Desk Lamp S1 suddenly stopped working with my app through wifi.
Thank you.
Hi,Whitelist me alse please, I need LAN control for HA
mi id = 1613950460
Models: ceiling5 and bslamp2
Region is Europe/Frankfurt
Hi Morgan,Whitelist me alse please, I need LAN control for HA
mi id = 1613950460
Thank you helped me!
Done
Sorry,your products belong to Mijia ceiling lamp and bedside lamp. According to Xiaomi’s privacy policy and other reasons, LAN control is not supported at present, and adding the white list cannot be solved
Hi Please help, same issue with two 480 lamps, cannot connect remote or dimmer anymore after update!
My Mi ID is: 6392217317
Thank you!!
Can I get also to the whitelist, please?
Mi Id: 6282732358
my id is
235292635
thanks
Model: yeelink.light.ceiling3
Firmware: 2.0.2_0048
Server: Frankfurt
Symptoms: Random offline status for over a year. Only recoverable after power cycle.
My ID: 1577038020
Please add me to whitelist.
Thank you very much!
Hi,can add me into the white list too
5 of my Yeelight stop working after a year , and wont worked no matter how many times I tried to power cycle it
Yeelight ceiling light 320 x4
Yeelight crystal pendant x1
mi id : 6421218463
server. : asia & oceania (Singapore)
thanks a lot
