This is my second light bulb with this symptom.
The light bulb was working as usual. Suddenly the White Yi light bulb (It is a color Yeelight bulb but I set to White) turns to color. When i check the app, the app was on White. So suddenly i lost the White function. I did not update the Yee light bulb. After experiencing the issue, i tried the following but cannot solve the problem :
- Set White trough the App, but the light bulb is color even if i select White in the app.
- on and off the light bulb. Still the same
- Reset the light bulb. Still the same. When reset the light bulb, its in color and not blinking white mode.
- add again the light bulb into the app. Still same issue.
Iooks like the light bulb cannot go back to White physically. Please help.
