have problem,my strip can’t connect to zyxel router. Before three months i had not this problem. the other smart lights brands works But now after reset two yee strips and one bulb cant connect any morenat zyxel. At other routers they can connect i tried .
Can you check if there is a problem with the router Settings? For example, you can work with multiple frequency in one, or you can connect to 2.4g network. Yeelight Many devices do not support 5G network
Is your router configured with WPA3? The current version of Lexin module is not fully supported for WPA3. It is recommended that the router configure WPA2 and try to connect.
