The firmware upgrade of the yeelight display hanging lamp failed, the lamp is now uncontrollable and flickering
When the firmware of the yeelight display hanging lamp reaches 13%, it stops moving, and the upgrade fails. Now the light flashes once and then off, the color temperature will change, and the brightness will also be bright and dark. . . I can’t reset it after powering on it for 5 times and failing to connect to Mijia. What should I do? Is there any other way to reset? Or how to upgrade the firmware again? thanks
The developer doesn’t care about us. Nobody wants to be held accountable for their mistakes.
I got into a similar situation.
I plan to flash third-party firmware: GitHub - syssi/esphome-yeelight-ceiling-light: ESPHome custom firmware for some Yeelight Ceiling Lights
