Hi, I’m having a problem that when I try to run a scene on Alexa, even though the action is confirmed by Alexa, the light does not change at all.
I’ve tried to run the scene on the yeelight app, and it works fine there.
Hi all, i have the exact same problem
Scenes work fine in the app, but Alexa refuses to turn them on, even though she says she did.
I can confirm that SCENES from yeelight App are not executed through Alexa
Sam problem. Server Europe (Frankfurt). Yeelight, can you support us here? Problem appeared 2 days ago
Same here
Why stopped scenes suddenly working with alexa?
Edit: Solved same day.
I think it’s working again, I just tested and the scene was executed as it should.
Also, it does not work (anymore) with Google assistant
