Saludos. He probado tres parejas de bombillos mi led smart bulb y ninguna de las seis unidades se ha conectado a la apple home. He utilizado MI HOME y YEELIGHT.
Lo mas que consigo es que me pida el número de 8 cifras de configuración de APPLE HOME.
El firmware esta actualizado.
Tengo otros bombillos iguales que si conectan sin problema alguno con las dos apps, espero que haya alguna solución para integrar el resto a la app home.
Gracias.
Greetings. I have tried three pairs of light bulbs my led smart bulb and none of the six units has been connected to the apple home. I have used MI HOME and YEELIGHT.
The most I get is that you ask me for the 8-digit number of APPLE HOME configuration.
The firmware is up to date.
I have other light bulbs the same as if they connect without any problem with the two apps, I hope there is some solution to integrate the rest into the home app.
Thank you.
