I have three Yeelight bulbs here. They are working well and they are already configured in Yeelight app (also did in Mi Home before, sucessfully). However, I tried everything but I was not able to integrate it with Alexa. I followed all steps from the website, but Alexa does not recognise my bulbs. What should I do, please? Can You give me some help?
I’ll give you some infos about my bulbs:
Smart LED bulb 1S (Color)
Model: YLDP12YL
I am in Brazil right now (I saw some people changing servers and I don’t know if it matters on my case).
Hi. I did a little background check, and your lamp supports Alexa。
There is a problem to make sure your firmware version number is up to date?
If you’re up to date, try this: unstrap three bulbs, add them one by one, Scan Alexa for each light bulb, see if it can be detected, and don’t add three lights at once. Try this method.
I was doing doing the right steps, but for some reason, despite using the same phone number, two different Yeelight accounts were created. When I fixed it (using the same account in Yeelight app and Alexa) the connection worked!
