I have seen multiple requests here about the fact that the music mode is disabled for the ceiling lights. I wanted to make the mood light from the meteorite pendant light change based on some events (the color of my ambilight and other lamps) and I discovered after reading the api that the method is not available on the ceiling lights.
Is there a reason for this feature to be disabled? Can some feature like this be added in the future? Even if enabling a music mode for a mood light is different than the normal rgb bulbs, I do not see any big limitation to justify this feature not available on ceiling lights, right?
Only enabling the set music and flow methods for the mood/upper/ambilight from the ceiling light at first would be enougth so that developers could work on its own automations…
