YLXD16YL - not pairing with remote control (YLYK01YL)
I purchased on Amazon Italia n ° 2 LED Ceiling Light 450 (YLXD16YL) visible at this link: https://www.amazon.it/gp/product/B083ZFYG47/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1.
Problem: I cannot connect the supplied remote control (YLYK01YL) to either of the two lights.
I then tried to connect the remotes in question with other Yeelight lights and I was able to pair correctly, so the remotes are OK; unlike other remotes that I already had these also do not connect to the new lights.
I hypothesize therefore that the probkema is linked to the firmware present on the new lights, which is the version: 2.0.2_0048.
Can someone help me ?
Downgrade, but how?
Thanks.
hi,give me your MI ID,after that you can update the firmware to 2.0.6_xxxx
MI ID: 1857751312
Thanks,
done
Hi, please help me!
My Mi ID: 1663380640
Thank you so much!
Hi, I have the same problem can you please help me too!
My Mi ID: 8163905783
Thank you in advance!
Hi, please help me!
My Mi ID: 1660888930 (fw. Ceiling Light 550C)
Thank you so much!
Hi I also updated 2 of my devices to the latest version with with the xiaomi mi or yeelight app, 2.0.2_0048, since then I can no longer connect the yeelight remote or Dimmer!
The two lights are now causing a lot of issues as I can not control them, please help! Tried everything and have been reading everywhere for a solution, connecting Yeelight app to mainland china, europe no solution seems to pair back the remote or Dimmer switch to my two ceiling lights.
The two devices are the same, the Ceiling Lights Starry 480. YLXD17YL the remote worked before when I purchased the lights 2 months ago, before making the firmware update.
Remote model is YLK01YL and the dimmer model is YLKG07YL.
My Mi ID is: 6392217317
Thank you!
Any help would be greatly appreciated. I have two new products that are basically dumb now, after the last update…
Same here. I cannot pair dimmer YLKG07YL and remote control YLYK01YL to Ceilight light YLXD17YL.
Please take care of this issue.
id 1731383502
