Today I bought a Mi LED Smart Bulb Essential(White and Color). I can connect and use it using the Mi Home app. Since it has no music mode,I tried to connect it with Yeelight App. I reset the bulb. It flashes and stays white. I can see a yeelink-light-color5 ap on wifi but the light won’t show on yeelight app during scan. I tried it several times but the result is still the same. When I first connected the bulb using MI Home,I updated the firmware to the latest version. Does this bulb not support yeelight app? Or Mine is a faulty one? Is there any way to connect or anybody faced similar issue?
Tengo el mismo problema, estuve buscando en el foro y me di cuenta que dicen que es por la versión del foco, algunos modelos ya no son compatibles con la app de yeelight, estoy decepcionado
Osea si no lo puedo conectar a Google home esto es un engaño publicitario por que en la caja dice compatible con Google home y Alexa lo peor de caso que yo compre 4 en una sola compra
Hi
Is that working your bulb in yeelight application,I am facing same problem.
Pls help me
