Yeelight YLXD02YL + MJKG01-1YL | FlexSwitch problem
Good day! I have a “Yeelight JIAOYUE YLXD02YL” ceiling lamp with a “MJKG01-1YL” type wall switch and I wanted to enable FlexSwitch functionality. The following happens: If I enable the FlexSwitch on the wall switch physical device (turn the screw to left direction with a screwdriver) the wall switch receives electricity only when I hold it in “ON” position with my hand. As soon as I release my hand (=I do not hold it in ON position) it does not get electricity. On my phone of course I enabled the FlexSwitch for the ceiling lamp but still it did not change anything: as soon as I do not hold the wall switch in ON Position it does not get electricity and the ceiling lamp turns off. In normal switch mode the 2 devices are working perfect. Could you please support me in make the FlexSwitch working? I’m quite sure that there is a trick I was not able to figure out. Thanks in advance!
Hello, it looks like the wrong wire is connected. It should be connected to L1 and L12, not L11
very helpful for me, I just joined the forum to post the same question and voila!!
Thank you very much
