I’m reseting my LED Yeelight Strip.
IT turns into different colours and ends in Orange/yellow. Than I start connecting them with my local W-Lan Router. It Starts to Finish the Job from 0% to 100%.
Than there is a Message in the Yeelight App: Connection TIME OUT - Check current Network and Scan again…
I can restart it over and over again. Always the Same.
This is ODD because:
Im using a Xiaomi Ceeling Light and Nightstand Light in the Same room and Same Network with No Problems. I installed them the Same day…
My Router: FRITZBOX 7530 / FRITZOS 07.20
IT uses the 2,4 and 5 GHz range.
I Change IT to only 2,4 GHz. Didn’t Work.
The Others 2 LEDs are Wirkung in the 2,4 GHz range, I checked it. So the LED Strip 2 Coulde usw this too.
Any ideas to solche this?
