Downlights / Spotlights - Any dimmer compatible
Does anyone know of a compatible Dimmer for the yeelight donwlights / spotlights?
I´ve been checking the following lights:
Spotlight Yeelight YLSD04YL (Bluetooth Mesh)
Downlight Yeelight YLSD01YL (Bluetooth Mesh)
Yeelight M2 Downlight (Bluetooth Mesh)
Yeelight M2 Spotlight (Bluetooth Mesh)
I would like to be able to dim these kind of lights through a dimmer, not via application.
Do you know of a compatible dimmer for any of these lights?
PD: I also own the Xiaomi Gateway III in case you can propose based on the gateway version.
Thanks in advance!
Do you know how to dim or bright via intelligent scene?
I finally used this switches:
WXCJKG11LM
WXCJKG12LM
WXCJKG13LM
You can create scenes in the MI Home App.
Both, the lights and the switch are compatible with the app.
Would be nice to know if the d1 aqara switches were compatible
Yeah they are, but you need the new xiaomi gateway which is compatible with both of them:
  • Bluetooth Mesh Compatible (Downlights)
  • Zigbee 3.0 Compatible (Aqara D1)
Once the devices are registered in the gateway … you can create the automations.
Are you sure?!?! I haven’t read that anywhere, nearly impossible to find out compatibility details
