Hello
I am using two Mi LED Smart Bulbs with the Xiaomi home app . In the app i can set the white colour as it should be . I paired the app normally with google home. The voice commands work.However when I use google assistant to “set lights to white” the colour is set to a light yellow, and this can be seen afterwords inside the app itself. Is there a solution to this ? thank you
