今天凌晨两点(2020年8月3日)的时候家里的灯突然很多灯同时亮起,排除停电(插电监控设备一直工作),也没有人在房间里。能帮忙查询一下原因吗?现在还未入住,但是半夜突然亮灯还是挺惊悚的。
账号 668949652
账号 668949652
根本就没人管,我发帖都快1个月了 官方都不理不睬 可能是没用英文吧。。。。
Hello, can you tell me what kind of light do you use?
Maybe I can point you in another topic where this was alrady discussed.
Hi , thanks for your responding.
I’m currently using the 筒灯 筒灯 and 白光灯带 灯带. I saw these two products was turned on automatically when there’s no commands was sent. (they are not using the same switch)
however, 吊灯 are not turned on.
I saw it from inside the security camera and made sure there was no power outage.
I have the same issue with the downlight sometimes with no reason it’s turning on without pressing the switch. I have supposed that can be from an electrical "short"from my electrical cabinet( no neutral line connected in the switches)
I wilk try to solve this first. For the light strip I can’t tell you because I not using it for the moment. For the blubs in. case of power outage you can set default state when power comes back.
I’m pretty sure that’s not the power thing.
Ok than, hope that you will find the problem and you will share it , I am also interested in this topic and how to solve it
I have the same issue when lights suddenly turn into moonlight mode with no reason
