Hi there,
I have an issue when using automation with my 1S color bulbs, I have 3 rules (light up/down and toggle), controlled by an AQARA switch.
The switch seems to work as the other lights that are controlled by this automation are turned on (lightstrip and first version color bulb).
For the S1 bulb, I see “error” without further explanation.
The bulb can be controlled via the app and google assistant, but the automation rule seems to fall short.
This is reproducible in both rooms that I have 1S bulbs
I’m using:
mi home 5.6.99
server: china mainland
Yeeligh S1 color
FW: 2.0.6_0027
LAN control enabled
Flex control disabled
Router MI router 4
