I have a problem with my Yeelight 1S bulb. I’ve got 3 of them and all working wrong. When set to 75% and More everything is ok. When dim Light to 75% and down bulb is changing color, flashing and goes down. Example:
White color - 100%: everything good, 75%: everything good, 50% to 75%: changing color to flashing dimmed green, under 50%: goes down. Bulb is not working under 50% Light intesity
Purple - 100%: ok, 75%: ok, 50-75%: changing to dimmed flashing red, 50-0%: not working
This is how it looks like (Video): https://1drv.ms/v/s!Am0LWS-LMd1KhctEz3zBRhvmmo2ZNA?e=31R4Xo
Tested with 3 other new bulb, few lamps and homekit, mi home, yeelight app. Router is huawei b528, Factor setting, only 2.4ghz wifi enable.
When reset it working Great for few hour (Couple times on and off) and then as above
Please, give me solution of the problem or update to fixed firmware Version. Or downgrade to earlier firmware.
Mi id: 1800377821
Thenk You,
Greeting, Mat Lesn
