Sometimes this light works fine with Homekit, but it generally disconnects at least once a day. There seem to be two ways to get it to connect:
Cycle the power. Wait a while. Maybe it will reconnect and maybe not.
“Play” with the light for a while in the Yeelight app. It will initially say “disconnected” but after turning it on and then off several times it will eventually reconnect to the Yeelight app. Some time later it might reconnect with HomeKit.
I’m away from home a lot, so these “solutions” aren’t really much of a solution.
I have communicated with Yeelight support on this, but they seem to have given up and have stopped responding.
Please don’t suggest that I reset the light. I have done that dozens of times. It works briefly but then the light starts disconnecting again.
Should I just dump it in the trash and try another brand?
There are several similar but separate issues
Connected in Yeelight/Xiaomi but not homekit -> Wifi fine but LAN connection with homekit hub disrupted
Connected in homekit but not Yeelight/Xiaomi -> Wifi fine. No Internet
Disconnected in both -> Wifi disconnected, Check device list in router
For the third case I fixed mine by binding MAC to a fixed IP on the router
Yours seems to be the first issue. I sugguest your router may be blocking some local traffic so try a different router to rule that out.
If it were any of the things you suggest than other devices would be affected. All of my other HomeKit devices work fine. It’s only the Yeelight that periodically disconnects from both HomeKit and the Yeelight app.
The Yeelight has a fixed IP address. Even when it is “Not responding” in HomeKit and “disconnected” in the Yeelight app, I can ping it:
MrMuscle:~ mnewman$ ping -c 3 yeelight
PING yeelight (192.168.0.200): 56 data bytes
64 bytes from 192.168.0.200: icmp_seq=0 ttl=255 time=294.554 ms
64 bytes from 192.168.0.200: icmp_seq=1 ttl=255 time=210.619 ms
64 bytes from 192.168.0.200: icmp_seq=2 ttl=255 time=131.438 ms
--- yeelight ping statistics ---
3 packets transmitted, 3 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 131.438/212.204/294.554/66.601 ms
Your first statement isn’t necessarily true because a few of my bulbs had issues while others didn’t.
Now since you can ping them Wifi issues can be ruled out, which was what I had. I’ll let others chime in on this.
I never I had a bulb pingable but not show up in Yeelight. For homekit some do become ‘unresponsive’ after a wifi reconnect due to a router restart. It’s always resolved after power cycling
Yes. I can often resolve the problem by power cycling. But, that doesn’t do much good when I’m away from home for a week or two. I need a bulb that doesn’t need resetting or power cycling all the time to keep it connected.
I bought this bulb to replace a Koogeek bulb. The Koogeek worked fine, except that after power outage it defaulted to ON. Which, of course, is no good when you’re away from home and can’t turn it off in the middle of the day. With the Yeelight, you can change the after-power-outage default. But, that doesn’t do much good when the bulb itself is totally unreliable when it comes to Homekit automations.
So, now I’m back to using the Koogeek light because it stays connected.
Here’s another interesting tidbit. When I first got the Yeelight I could use the LAN Control to control the bulb from the command line. Then that also started to fail and now it doesn’t work at all.
I feel you. Unfortunately, too many variables with Wifi bulbs. It could be your router or it could be the bulb. Some routers don’t play nice with yeelight’s wifi chips, which has nothing to do with the router’s quality.
If that were the case then I’d be able to detect the connection problem. I used Wireshark to monitor the connection between my machine and the Yeelight and there is absolutely nothing unusual. The correct packets go out. The correct packets come in. But the bulb doesn’t respond. It’s not networking. It’s something else.
The 1S bulbs have a bug in the v2 firmware which freezes them after a while. This has been unadressed from Yeelight since a few months now. I have two 1S bulbs which worked fine when i had them on the v1 firmware, after i updated to v2 they are unusable…
So its now April 2021 v2.0.6_0030 and all 4 of my bulbs disconnect from HomeKit within 24 hours. I can control them with yeelight app still but not HomeKit. Google router.
Wish I had bought the older color ones they were reliable
I noticed an issue with Homekit Hub on my home. The status of my home hub (appleTV) was standby with no other home hub as active. Most things were working except the new g2h Aqara camera for streaming remotely. I signed out of iCloud on ATV and back in, disconnected and reconnected Homekit and camera working better now… as a side note seems like this may have solved the color 1s connectivity issues. It the camera hadnt arrived today I would not have known.
I have a similar issue. Have a bunch of Xiaomi and Yeelight lights but only the LED 1S(Color) don’t work (in my case) in Alexa. They did before just fine, and all the other lights work fine. They work in Xiaomi home and in Yeelight apps so connectivity isn’t an issue, but just for some reason cannot control these anymore in Alexa. Very frustrating, family can’t control the lights anymore.
