Hello everyone!
It’s nice to be part of what seems to be a big and important family!
I need to pass one part of the first generation of yeelight RGB ledstrip through a small hole in order to make it all tidy and good looking.
However, the actual ledstrip is too thick and the other side has a bulky power adapter.
So I was thinking of teardown the Controller, pass the cable through the hole and then connect it back.
What do you think guys?
Thanks a lot!
Spiros
It is not easy to open though.
So I was thinking of cutting the wire and them solder it back.
Do you know if the wire can be soldered and still work fine?
Has anyone done it before?
I think it’s much easier to deal with the wires only. If I were you I’d just cut and then splice the wires.
I imagine there are multiple wires in each of the white cable so splicing each one correctly is key I guess.
Sounds like a solid idea!
I will do that in the evening, I will take some photos and I will let you know the results for future reference!
