Hi, i have the regular dimmer, that changes electric power in regular old celling lamps. Now i want to buy Celling LED light, but i’m not sure if it will work with this type of switcher. I need leave it turned on like on 100% dimming power all the time, or dimming functions will be avaliable?
Regular dimmer functionality
No, you can’t use the dimmer, it wold DESTROY the lamp… I wouldn’t even considering installing it with dimmer. Better replace the dimmer with regular switch. If anyone turns the dimmer, it would SURELY destroy the lamp. It has WIFI module which has to run… the dimming is done in “software”…
wow, thanks, i almost bought the lamp and i have no switches to replace now
