I would like to ask if somebody has the same issue as me and if somebody has any idea how to solve my problem with the ceiling light.
- Type : Yeelight YILAI YlXD05Yl 480
- FW : 2.0.6 0026
- Server : China
After 2 months what I (my girl) was used this lamp was everything OK. But one morning stopped working properly. Its turning off from time to time, but the worst is I am not able to change brightness/color/temperature/kelvins, so nothing… I am using the yeelight APP through directly router/wifi so without HUB (this is working in another lamp(type) in another room very well). Through App I can only switch the light off/on. When I try to change the light,the lamp get the signal,because there is some reaction, but it looks like it “immediately” reset to some “standard” value.
I tried reset few times the ceiling (turned off/on and pair with app again), I tried switch fuse on/off, I tried switch servers, but nothing helps…
Could be wrong FW in lamp or the lamp is broken after 1 and half month ? I did an order of the same lamp and I hope I will have no more problems with that.
Jakub.
