Hi all, I’ve create a NPM package for controlling Yeelight bulb base on the spec. Hope it helps. Suggestions and PRs are welcome. Cheers.
More detail can be found in link.
yeelight.io
Description
yeelight.io
is a simple library for you to control YeeLight LED bulb through LAN.
Installation
npm install yeelight.io
Usage
Using Bulb type
'use strict';
const { Bulb } = require('yeelight.io');
const l1 = new Bulb('192.168.1.227');
l1.on('connected', (light) => {
console.log(`connected to ${light.ip}`);
light.toggle();
light.disconnect();
l1.on('disconnected', (light) => {
console.log(`disconnected with ${light.ip}`);
l1.on('error', (light, err) => {
console.error(`error [${err.message}] occur on ${light.ip}`);
light.disconnect();
l1.connect();
Using pre-implement methods
'use strict';
const { toggle } = require('yeelight.io');
toggle('192.168.1.227', (err) => {
if (err) {
console.error(`error [${err.message}] occured on 192.168.10.227`);
} else {
console.log('toggle 192.168.1.227 success');
License
MIT
