Tried this and still same problem
Bedside lamp 2 going offline.
Tried many things, including setting a static IP address for it. So far no luck in getting this issue resolved.
Would you please whitelist me?
Current firmware: 2.0.6_0030
MI ID: 1622094703
I have 2 beside lamp… 2.0.6_0039 the same problem.
With previus firmnware work perfect!
Pleas add me for whitelist id:563634746
8 days with firmware 2.0.6_0039, the flight is normal.
Same here. Often disconnects and / or socket errors in HA. Please whitelist me.
MI ID: 6338023937
Server: China Mainland
Many thanks
12 days working.
HomeKit, Mi Home, everything works!!!
Chinese server.
Hi there I selected the Chinese server and updated to 0033 still same issue persist can u push latest firmware to me id 1607296043
Please add my to whitelist
Hi all…
Please update or downgrade firmwarI can’t use the yeelight with this firmware!
many thanks
whitelist id 563634746
on the 17th day everything broke, the lamp does not respond again
firmware 2.0.6_0039
Correction, the problem is only in HomeKit, if you turn off the remote control of the lamp, that problem is solved, the lamp works.
Either HomeKit or remote control
Hi
Please, whitelist my id
Router: Xiaomi MIR3G
Firmware: 0033
Server: China
Alexa dont work with the skill Yeelight
Original Firmware works
Why I can’nt update to latest Firmware? I need firmware 2.0.6_0039 or latest
does not connect to wifi
Thanks for your help.
Hi, An “update” is supposed to improve the device. It must be tested before launching. However, unfortunately, Xiaomi launches “Updates” in many of its devices, in which it worsens the operation, restricts its use, etc. It’s a lousy policy. Why don’t you listen to your European clients? There are people like me who are loyal to the brand. But many people don’t buy a brand if they have a bad experience. It’s advice.
If something works, don’t touch it! And so many updates with 0 improvements. At least from the customer’s point of view. Cheers
Everything works for 30 days, except for remote control.
firmware 2.0.6_0039
1914391220
6284673860
Can you please set me on whitelist for firmware 2.0.6_0039 too.
I want to controle my Bedside lamp with Alexa again.
Same issue with the wifi keeps disconnecting.
Can you please whitelist my ID: 6385164721
Please whitelist my id: 6279402726
I cannot upgrade or downgrade from 2.0.6_0030.
Hello @chyhaiyuan,
Since I bought the Lamp from today, everything worked fine (connected to Google Home, Yeelight, HomeKit and Google Assistant).
Today I updated the Lamp 2 to latest firmware and everything stopped from working. The Lamp does not responds anymore in the previous apps, saying “out of line” or “not connection” issues. So I cannot use the mobile to controle it neither voice commands are enabled.
Can you please add me to the whitelist?
Firmware: 2.0.6_0039
Server: Europe and Africa (Frankfurt)
hi alegr3
please select china mainland server in app, then upgrade the lamp to the internal test version 2.0.6_0040.
