Do you have a solution for this problem? I see a lot of posts about it…
My code is not correct to use on apple home kit…
MAC: 7C-49-EB-56-36-67
Can you do something to make this works? Create something via firmware, via china servers…
Maybe connect this to a hub and the hub put this light in to homekit?
Did you try 111-22-333? If that doesn’t work, then you should ask for a refund or replacement. The fist batch product has some issue (which is caused by the chip vendors toolset, 1 out of 10000 chance). Sorry for the inconvenience.
Then you should return the product or ask for a refund, really sorry, we solved this corner issue recently and unfortunately your products should be the unlucky batch.
