I had the same problem, i resolved this issue installing the Yeelight app and adding the bulb from there to My Home in Homekit.
I’ve made the same but it doesn’t work when I turn wifi off
I also am having the same problem my id is: 5319851316
I have the sale problem on HomeKit can i participaste on beta my id is 6329820682
Is possibly Can’t you send me the beta firmware
I have the 2.0.6_0035. Not is possible connect with HomeKit my Buls
My ID is: 1594617310
Model: yeelink.light.color3
Best regards.
[/quote]
Hi . I am not able to upgrade my firmware for my yeelight bulf from firmware 1.4.1-48 to 1.4.2_0076. It either keeps failing or goes to 99% and is stuck there.
I also have other yeelight bulbs and had updated them earlier and they updated fine but I don’t think it was the initial version. They got updated from the recently updated version to 1.4.2_0076.
Since I cant update I cant change the settings of the bulb as it says I need to update first and than I can many changes. I have 6 more bulbs and I cant do anything with them
If I try the through the android version its stuck at 1% and not moving forward.
I tried resetting it and it did not work.
I tried creating hotspots and it did not work.
I tried using different routers and it did not work.
I am on the Singapore server and my user id 1733078537
Please help help help
