My yeelight 650 were tested and was working initially. But after mounting the base plate to the ceiling, the light cannot be turned on with the physical switch on. Remote couldnt be connect. Is it becausr during the testing, we used the remote to turn off thus causing it to be off and unable to on now?
Check if the metal contact is good between the holding pad and the lamp.
