add me to whitelist pls
Mainland China Server
Please add me to LAN Control Whitelist. I bought YeeLight products with intention of using it.
1888286923; Germany.
Please Help me !!!
I have an issue adding my other Bulbs on Homekit (3 on 6 doesn’t connect on HK) : Bulbs are installed both on Yeelight App and Xiaomi Home App.
HomeKit button available on MiHome but nothing happening when clic on “Home”. On Yeelight when I try to link to Homekit, it shows a popup for generating a Homekit code, then it shows the HomeKit Popup with camera, when you pass it with the code demand it switches on Homekit App, without the Bulb I want to pair …
Models : Mi LED SmartBulb (White & Color) - MJDP02YL - Europe server - Firmware : 2.0.6_0035
Account : 6353652102
Device : iPhone 12 Pro - iOS 15 - Xiaomi Home & Yeelight Apps updated on last versions
Please also add me to the whitelist for using my Smart LED BULB 1S with my Home Assistant !
Current FW version is 2.1.7_0037 and is inresponsible whereas on other bulb with FW 2.0.6_0065 it works perfectly.
My ID is: 6270747092 // Europe server
Thank you for that !
Please whitelist me too.
Server: Europe
Having a lot of trouble with this…
Thanks in advance!
Please whitelist me also.
Server: Mainland China (Beijing)
Model: yeelink.light.ceiling22
Device model: Mi LED Ceiling Light 450
Current version: 2.1.7_0038
Trying to use this light in HA but with no success.
Best regards.
Pease, add me to the white list.
Server: Eurore (Moscow)
I need the LAN control for my Mi LED Smart Bulb (white and multicolor) and for other devices in the future.
Thanks.
Please add my account to the white list:
MI ID: 1641565731 (China / Mainland)
Model: bslamp1
I need to use the LAN control to integrate with home assistant
Please add my account to the white list to downgrade firmware or downgrade by yourself:
MI ID: 1717590315 (China / Mainland)
I have problem with my strips after firmware update from 2.0.6_0015 to 2.1.7_0018 (every day strips lost a Wi-Fi connection)
Apologies but did the request to add you to whitelist was even considered?
Did you got access?
Just let us know.
Otherwise, you need to find other methods to activate Lan Control
Server: (China / Mainland)
I need the LAN control for my Mi LED Smart Bulb (yeelink.light.color3) and for other devices in the future.
Thanks.
Hello, Pease, add me to the white list.
Updated to 2.1.7_0015 and bulbs 1S stoppped working Please help downgrwde to 1.x.x where it worked
Please add me to the beta whitelist please, having the same problem!
Mi ID:8159224039
Please add my account to the white list to downgrade firmware or downgrade by yourself.
I need lan control
My ID 1690225110
My Color Light Bulbs 1s are randomly not responding in my Home app. Could you help me fixing the firmware?
ID 6432607621
Europe
Thx
Hello there, my ID 1580036283 (Singapore server) please add me to whitelist to downgrade back to 2.0.6 to all my bulbs/strips/bad side lamp
Have same issue with “not responding” at some point in homekit. I got like 12 bulbs, most of them I didn’t updated to 2.1.7 fortunately but all my led strips, 1s bulbs and bedside lamp I did upgraded and now it’s just stoping to respond in HomeKit (In Mihome works fine but all my automatisations works thru HomeKit and siri)
So here is a few things that I found:
- it’s mostly starting to glitch when I coming home from work after few hours
- to “wake up” my bulbs and other stuff I have to manually turn off/on at least !one of them! manually, rest will follow somehow and will start to respond as well. I tried many things and nothing helped to fix this issue
- all my 1se bulbs (which is working on 2.0.6 as a highest firmware) and 1s bulbs which I didn’t updated - works stable and had no issue with connection
So please add me to whitelist or whatever so I can downgrade my stuff back to 2.0.6. Thanks
Need a downgrade, keep getting disconnected now.
Server: Europe and Africa(Frankfurt)
Bulb: yeelink.light.colorb
Hi I have a YLDP13YL with firmware 2.1.37 and have the same problem disconect many times. Is possible a downgrade, my ID is 6347790656 / Server: US (Oregon).
Best Regards,
Thanks.
Hi, i need Lan Control please for Razor chroma
Mi ID:8154380023
