YLKG08YL remote control not switching between Daylight/Moonlight mode with Meteorite lamp
Hello!
Yeelight Meteorite is working as expected and is working with Yeelight app on the phone.
YLKG08YL dimmer is connected to Meteorite and is doing almost every job it should.
The only problem is that it is not doing anything if you double click it.
It should be switching between Daylight and Moonlight and it is not.
If I manually set the light to night (moonlight) mode in the application, I can turn brightness to more or less with a dimmer.
But switching between the 2 modes is not working.
Is this normal and it is just not working with this remote?
Is anybody that has basic bluetooth remote control and it is working it?
Any kind of advise would be appreciated.
Thank you.
Best regards,
Tomaž
