Does the bulb last longer when I turn off the bulb without applying it? for xiaomi yeelight e27 (
Not from the lamb key)
The working life of the our bulb is 25,000 hours, which means that if you don’t use it, it will not consume its life.
I was triyng say, if i turn off the bulb from the yeelight app does it away from 25.000 hours. Does it work just as same as if im turning off the switch?
