Hello…
Can anyone point me solution for downlight that uses wifi? I just can find the new Mesh solution, but that needs a hub and my beside lamp doesn’t work as a mesh hub unfortunately.
Hello…
Yes, you are right. It works with a mesh gateway. And bedside lamp can’t work as a mesh hub.
Can you tell me if the new Mesh solution is compatible with the European server?
Yes, we are working on new mesh product to support these mesh devices.
but i can use it right now in Europe ? Because i need a solution for downlights, and i only found the mesh solution.
It should be work with bluetooth mesh gateway, such as: Yeelight voice assistant, Xiaomi Xiaoai smart alarm clock, and then the bulb can be connected to cloud.
